Engine/Transmission (1994 - 1998) power steering pressure test
Hello all,
Someone mentioned in another post, that there was a way to test the pressure output of the power steering pump, but I can't find it. Any ideas where it is?
Thanks
Ryan
You would affix a pressure gauge and some adapter fittings for the pressure and/or return to perform pressure test(s) and volume testing (gpm). The fittings are metric, so that would mean some -AN, fittings from a hot rod shop etc. ?
If you suspect problems, a reman power steering pump with reservoir is so inexpensive, why bother with further diagnostics? If you are concerned about the reman quality, keep your core and pay the core price. .
Good luck
Andy
