My power steering pump was starting to leak so I replaced it with a reman from NAPA. That was about 2 weeks ago.
This afternoon after straightening out from a U-Turn, the pump failed. I managed to drive the 'Tank' back to the shop and ordered a new P/S pump. I installed the pump and wouldn't you know it. Pump # 2 is also defective. It would not pump any fluid at all. The first pump had about 1/4" of play. This replacement pump checked out OK; no play at all. However, no output. So, I took it back down and by that time, it was too late to order a new pump.
Before I install this 3rd pump, what should I do to make sure this one is not a dudd? What are odds of 2 pumps in a row being bad? Isnt' there any QC at NAPA?
Has anyone else every had such bad luck with NAPA reman pumps?
Martin
Martin
