Engine/Transmission (1998.5 - 2002) Power Steering Pump Exploded
Engine/Transmission (1998.5 - 2002) Engine cuts in & out (MAP ?)
Ok, I got your attention.
I would like to know if anyone has an exploded view of the power steering pump? I am going to do the vaccum pump reseal and I have a leak at the pressure fitting on the Steering pump and figure I will replace the o-ring in it also.
Someone has had to have one of these pumps apart. Any tips on resealing a powersteering pump?
Pretty straight forward job if you can locate a reseal kit. I had to go back to '93 application to get one for mine. Weird, as they are the same pump. Just o-rings, regular and square cut ones.
Looked in the shop manual and there's no exploded view of the pump. However there may be something on the link below that could help . . .
powersteering
