i developed bad leak at my pump, noticed that the metal line coming out of the pump was loose, tighten it up, still leaked, took it off only to discover that the oring had desinigrated, replaced the oring, haven't seen a drop since.
my seal on the bottom of the steering box is leaking, ive got a seal kit, i just got to get the time to get under the truck and replace it. good luck with your problem.
wes
