Engine/Transmission (1994 - 1998) Power Steering Reservoir Leak
Our 96 DODGE Ram is leaking at back of the power steering reservoir at the fitting. Must the pump be removed to replace o ring in fitting? Dutch
Are you talking about the high pressure line o-ring or the o-ring on the fitting it threads into? Either way it can be fixed pretty easy without removing the pump.
