I used to live in York. . Do you know Carl Bean? (Central Maine Power, Senior Lineman)? My friend Tom Warmington (Warminton Plub & Heating) Or Steve Hay a contractor in N. Berwick, ME? David Starkey (Starkey Ford)?
Robbins or Sas Sanel should hook you up, although it requires a trip to Portsmouth, NH
Has the red light on the Nubble light turned green yet? Ah come on your were a teenager once. .
Edelmann
7910 pump rebuild kit
7918 pump seal kit
8709 pump shaft seal
8776 power steering gear reseal
Gates
350390 pump rebuild kit
351160 pump seal kit
348720 pump shaft seal
If the shaft is grooved much it may leak again.
I offer a vac. pump repair kit if the vac. pump to ps pump leaks on reassy.
Or do a search for CPFF (john strenkowski. . down in CT), ie Tri County Machine. .
Now go to Newicks and have some scallops and cod for me tonight, darn I forgot, bean and hotdogs (its Sat. not Fri. ).
Good luck,
Andy
