I have been fighting steering issues with my 98. 5 2500 for a while now. My latest adventure involved replacing a leaking gear box and all the power steering hoses. Ordered the stuff from Chip at PSS. I went to bleed the system and could not get any fluid to start pumping. I tried everything. Talked to Chip many times and he couldn't figure out why it wouldn't pump. He sent me a new pump, put it in and the same thing happened. No fluid movement. Then I got in my truck and gave it a bit of throttle and at last, fluid started pumping. I bled the system per standard protocol and have been driving the truck with no problems. Then as I pulled into my driveway, I felt a "thump" in my steering wheel and then I lost all power steering. I figured I blew a hose. Everything was intact. I found out that I can only turn my wheel to the right. Once I get to center going left it stops. I jacked the truck up and moved the wheels by hand and the same thing happened. I disconnected the steering shaft to confirm it is in the box and it still wont move past center. I hear a metal thump in the box when I try to turn it to the left past center. Any ideas whats going on? I am getting sick of swapping out boxes.
