Engine/Transmission (1998.5 - 2002) power steering
Engine/Transmission (1998.5 - 2002) Injector pump problems
Engine/Transmission (1998.5 - 2002) LMC wiring harness problems
hey guys, I am looking at changing the power steering fluid. the truck just over 100,000 miles, and never been change. what is the ez-way in draining the fluid. thanks
The easiest and cleanest way is to suck the oil out of the reservoir and refill then run.
Repeat as needed until the fluid comes out clean.
You will only get 8~12 oz out at a time but doing this several times will purge the old oil out.
I usually suck the oil & out refill every other oil change.
Works for me.
