. . a bit. Made some adjustments to pump today, turned diaphagm/ cone 120*. turned starwheel 90*, truck runs OK, but still feel something is lacking. Can only get up to 20-21#'s of boost before it starts defueling and max EGT I saw is about 1050* pre turbo, already turned power screw out approximately 2 turns a while back, that seemed to make a difference then, but still this one does not respond likey first '93 did. Is it one of those that needs the bigger injectors maybe? Smokes a fair amount at start up and if I get on it a bit hard down low, happened after power screw adjustment, just feel there should be more to be had from its current state. Was thinking possible boost leak, but that would make EGT's go way up, correct?
