Engine/Transmission (1994 - 1998) Power surging
Engine/Transmission (1994 - 1998) Yet another EGR question
Engine/Transmission (1998.5 - 2002) Gale Banks Fan - Great System!
This is my first post in the 2nd gen section. I usually hang around the 3rd gen group. This question is on behalf of my nephew.
He has a '96 3500 with auto transmission and about 240k on the clock. He bought the truck second hand and has had it about a year now. Problem developed recently while towing a medium sized 5th wheel trailer. He has a heavy foot and probably tows above 65 most of the time.
Last time he was on his way home (FL) from MN with trailer in tow he experienced an intermitant drop and then a recovery in RPM and power. He barely made it home by babying it along. When the trouble occurs, he can not get it above about 50 mph. During the events, it loses enough power to slow to below about 40mph. He has changed the fuel filter twice now with no noticable improvement. He took it to the Dodge shop and $75 later they could find nothing out of line; fuel pressures in the shop are 'normal' (don't have the numbers). It will not do it every time he drives it and it will also do the surging when not towing but seems to be worse when towing. He has no gages.
He is a pretty handy wrench but needs some ideas on where to look.
Any suggestions would be greatly appreciated.
Thanks,
George
Smoke?
GC,
Does the truck smoke when this problem happens? If, so what color of smoke is it.
Since he bought the truck used, did the previous owner replace the fuel supply/return lines? Clean the fuel strainer? I would go over the fuel supply system first (every rubber hose). If replacing fuel hose is worth the extra money to use only the marine grade fuel hose as it's wall thickness is about 3x that of regular fuel hose.
Please post what the "fix" was/is so we all can learn what to expect/check. :D
crabman :)
Put a fuel pressure gauge in the cab. I'll bet when he looses power he has low pressure. If you know that for sure then it will be easy to hunt down.
