I need some ideas on what to look for. The other day I experienced that dreaded running out of fuel sensation and then the truck died. After poking around for a few minutes I checked to see if the fuel shut off solenoid was working correctly and found that with the key on, the plunger was not up. I was able to push it up and the hold circuit worked. After priming it I was able to get it going and drove home. Got to poking around last night and found that the coil for the shut down relay is not powered with the key on. If I looked at the wiring schematics correctly, the only thing between the relay and the PCM is a splice #169. I think the PCM is ok because of other things that work, so suspect this splice is the problem. Wondering if others concur and possibly have other thoughts on what to look for. Also can anyone locate this splice for me. It is probably obvious because the relay is only a couple of feet away from the PCM, however it would be nice to positively identify it before going any further. If by chance my PCM has gone bad, where to buy a replacement and how much should I expect to get my pockets emptied. Thanks in advance for any ideas.
