Power upgrades-93
What is considered normal oil pressure ?
Truck died!
My friend just bought a 93. I think it has the 160 hp 420 tq. What can he do to up grade his power. Does he need gauges, exhaust? Thanks for the info. He plans to join the TDR soon.
Yes, the gauges and exhaust should probably come first, then he can move on to injectors, a different turbo housing, and getting the fuel pump set just right.
  • '93 250 LE 4x4 5spd 4:10 Loaded,dual 5" chrome stacks,12cm² turbo(37psi),PW injectors,K&N,pyro/boost,US Gear E-Brake,tool box,CB,10" AR rims, 285/75/16 Bf goodrich. "wirenut_21529" on Yahoo Messenger
  • '97 Ford B-Series school bus (5. 9 Cummins!)I'm gonna Bomb it!
  • '94 GMC 2500 6. 5L Turbo
PICTURES.
Don't tell you're buddy that the 160hp is "flywheel" HP... i dyno'd {when stock} at 124 horse rear wheel. I'm pushing 300 now. . we'll see after next weekend for sure. But yeah 1}exhaust
2}turn pump up
3}injectors
4}12cm housing
Greg's 1993 D250 4x2. . 5-speed. . extended cab. . longbed. . bright white. . tinted windows. . 4-inch stack through bed. . K&N air filter. . holes in air box... Tweaked pump... . PW injectors... 12CM housing... Isspro Pyro &Boost guages. . "The Phantom"
What kind of EGT's are you getting with the 12 cm2? How much boost?
90 W250, 5-speed, isspro gauges, 16 cm2, K&N, Borgeson shaft, JRE 3" exhaust, Banks Intercooler, Lucas injectors
I'd agree with the other fella's on the upgrades.
1) Gauges - Pyro,Tach,Boost (30psi min. )
2) Exhaust (I think 3" mandrel bent is good, 4" is perfect. )
3) Time Pump/Adjust
4) Injectors (they are 180HP marine application injectors for our year)
5) I suggest the 14cm wastegated housing. (I'd go that route next time instead of 16cm)
6) transmission temp guage if Auto trans.
7) DTT TC and VB kit. (I'm getting mine as soon as I can rob the sweety's purse)
MHO.
93. 5 D250 4X4,HD Spring Pkg, Rancho 7000's, Rear Swaybar,Dual Shock Front Stabilizer,BD Injectors,31/2" Mandrel bent exhaust,16cm 'Hot End',Modest Pump Tweaks/Timed,K&N Air,Isspro Pyro,Tach,transmission Temp,Auto Meter Oil Filled Boost Ga. , 3:54's, 4 Speed Auto, Clubcab, Aftermarket Reclining Buckets w/ctr Drop Down seat/console, Black over Silver, 21psi,285-65R-16's,American Racing Clear Coat Mags, Amsoil 15W-40HD Marine,12,000 lb. Warn Winch,KC Spots. 101,300 Kms (63,000 mi's).
Where can I get some 180 hp marine injectors and how much are they? I'v got him hooked up with the different venders for gauges. We have a muffler shop in town that does the 4" exhaust for $500. I'm not sure where to get the pump timed and adjusted. Any suggestions? We live in Idaho Falls, Idaho.
If you're looking for the 300hp marine injectors contact me. Several guys are running them now all are very pleased with them.
later
Don
Ol' Blue "First of the first gens: 1989 D 250 Ice blue met. 5 spd 3. 54, 155,000, Banks stage III powerpack, 3. 5" straight exhaust, pump adjustments, "'Ol Blue Special" injectors.
1999 3500 4x4 Chassis cab Emerald green ISB 5 spd 4. 10 K&N Filter straight exhaust 9 ft flatbed WARN fenderflares,Let, 275hp injectors installed, boost and pyro gages, VA plug'n power and Practical Solutions boost module. Jacobs E brake. Getting ready to install Banks Power Pack TLC!!
May buy another one in 2009!!
Check us out at:
http://donstractorrepair. homestead.com
