To operate the power windows with the door open and key off I used a Bosch relay with normally closed and a normally open terminals. When the door is shut power goes through the normally closed terminals to the window switch. When the door is opened the light switch triggers the relay and supplies power to the window control. It only works on the drivers side and the door has to be open before the relay trips.
01. 5 QC ETH/DEE 4X4 LB intense blue sport, everything but dead cow and cab lights.
