2nd Gen Non-Engine/Transmission power window question
Like Bill said check switches, also check wiring in door jams inside the black tubing. When I worked in automotive field I found a lot broken wires. I even found them in the semi's at the trucking company I work for. Over time the opening and closing the doors takes it toll on the poor wires. Check power at the switches first then go from there to track down the problem.
Randy
