My 03 quad cab 1 ton laramie has a problem with the power windows. None of the windows except the drivers window will work from their own switch. The driver controls will work all the windows. I have checked to make sure that the window lock is not on and it makes no difference which way it is pushed. I am wondering if the window lock switch could quit? Never used it so I would be surprised but that is all I can think of that would cause this problem. Does the plate that holds the switch just pop off? Any help on the matter would be appreciated.
