2nd Gen Non-Engine/Transmission Power Wire for Isspro Gauges??
Putting Isspro Trans, Boost, EGT gauges in a 96 2500 12V.
Where is the best place to get power from the ignition? Any instructions would be great!
thanks
eb
power for gauges
I will try to help out, I did the instsll on my 02 using pillar pods ispro and gauges. If your truck is set up the same way here goes. The fuse panel located at the left side of the dash open the drivers door and remove the cover door. I used an eccessory fuse I cant remember the # I think it was for the dash lites ,using a spade connector you can attach it to the original holder . However the best way would be to add a painless block from the battery and fuse your gauges. Still confused do an archive search for 2nde gen gauge install lots of info and ide3as . good luck hope this helps.
