I put a Powermax 3 adj. on my truck in february. the night of the install I noticed at around 90-95MPH it shut down on me. (not to mention it scrarred the Be-jesus out of me). I then inquired on here about it, and was told (Steve St. Laurent)the PM3 will "defuel at 2700RPMS and be back to stock by 2900RPMS" so I then talked with Mark and he agreed with that statement.
the problem with it is that the truck now "defuels" at 2400RPM's but only at highway speeds, in fifth gear. between gears it will run to 3000RPM's easily. but once i get to fifth gear at 85MPH it will shut down and not go any faster. i have tried to just stay in it and see if it would go faster, just without the extra power, and it wont. it stops at 85MPH.
I have asked Mark about it numerous times, and he is now telling me that the speed limiter is kicking in and to cut some wire to fix it. the only problem I have with this is the truck without the PM3 would run well over 100MPH, and even with it(PM3)turned on, but on level 0, it will run past 100MPH.
what should I do????
just yesterday, I was racing a guy and the truck would have smoked him, but just as I was at his door, it "defueled" this sucks...
Todd,
2001 Q-cab SB 4x4 5spd 3. 55's,PowerMax3 adj. , A pillar Boost/EGT,4" turboback exhaust,custom built aluminum airbox W/K&N-RE0860 through the cowl, 310HP/675ft-lbs and more to come...
Todd,
