'Pre' and 'Post Turbo' Gauge Reading
Losin a little coolant.
I have my EGT sensor 'Post Turbo,' and would like to know about how many 'degrees' I should add to get the temp that's 'Pre Turbo. ' I'm currently adding about 350 degrees to my 'Post Turbo' temps. I'm going to put a little red paint mark on my gauge to mark the max temp when I get the answer.
Thanks, Bob
Y2K Black 3500 ISB 4x4, 4:10 LSD,Auto,QC,SLT Laramie,"EZ", LB, Polished Stull Billet Grill & Fog inserts, Chrome Smitty-Built Step Rails, Mopar Chrome-Tipped Mud Flaps, A-Pillar mounted West-Tach Turbo/Pyro/Trans Temp gauges,Rancho 9000's set at '1',Diamond Plated Tool Box, OEM U. R. Bedliner + other stuff.
Fact:The First Fords' had 'DODGE' Engines! The new PSD's need them!
Good question,but you will never get a accurate answer. Too many variables,like RPM's
load,intake airflow and temp. ,exhaust flow,ie
4",no muffler ect. Pick a number between 250
and 500 and you will be close. If you are a Bomber,I would go pre turbo for sure.
[This message has been edited by Royal (edited 03-14-2001). ]
RobbyRam,
Have you thought about putting a pre-turbo sensor in and using a DPDT switch on your gauge? I have just installed my EGT guage with a switch next to it on the A-pillar to select between the two sensors.
1999 2500 ST LB 4X4 Metallic Red, 5-speed, 3. 54 gears, LSD, camper and tow package
Hey guys I've been lurking for several months now, trying to soak up all of this knowledge. Can anyone post some pictures of where they are installing the EGT probe on both Pre and Post turbo applications. I want the EGT and boost guage to be one of my first add-ons, and while I'm grasping most of what you guys are talking about, I don't have a clue as to where you are installing the senders. Thanks in advance. Jay
2001. 5 2500HD Quadcab SLT,4x4,auto,3. 54LS,24V CTD,Amber Fire Pearl Coat with Agate cloth interior. Used mainly to pull, XR50, XR70, XR100 and XR400R.
NRA Life member and Firearms dealer.
Welcome Tow Guy. about time you cut loose with the $35 #ad
Can you sell long guns to NM residence, how much do you charge for handeling paper work on an order????
Do a search on thermocouple probes, pyro probes, pyro mount ing, etc... .
There are a few posts that have detailed instructions and pictures.
2K, 2500, Quad, SB, 4x4, 3:54LSD, A/T, Cummins 505 ECM, reese 15k 5th slider, EASLEY BULL BAR, WESTIN NERFS, TA's, 9000's, stealth DD2's, Bully Dog Boost & elbow, ISSPRO pyro, boost & transmission, Turbo Lifesaver, JARDINE 4", DTT VB,TC,TC SAVER and AUX COOLER, PAC BRAKE, MAG HYTECH TP& DC, AFE filter onboard. Taylor Wing and Gear Vendors on order
pullee #1 26' Arctic Fox 5th
#2 22' car hauler w/ 76 Pinto 392cid or 68 Cyclone GT Cobra Jet FB
NRA-LIFE, VFW-LIFE, SoCSA-LIFE, SASS
TOWGUY, here's where it goes for pre-turbo. Post is placed on the exhaust elbow and not on the seam.
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Mopar tonneau,Lund bug shield,PM tractor utility back up lights,Penda bed mat and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
I have a pre turbo and a post turbo gauge both. The temp varies anywhere from 25 to 700 degrees difference, depending on how hard you've got your foot in it.
2001 Quad Cab Dually, ETH, SLT Plus, Isspro Pyro & 50lb Boost, 275 injectors, Banks Power Pack, custom "Scotty style" airbox, 4" open exhaust in front of duals.
'94 SLT 4x4 V-10, straight pipes and a K&N (can't find anything else :(
Thanks for the info guys. I didn't realize the turbo had to come off to do this. Guess I'll plan a day when the time comes.
Hey Towguy, the turbo does not have to come off to do this install. Getting started is the only hard part. Once your into it you'll find it's a snap. It takes you longer to decide how to dress your lines and mount your gauges than it does to actually do the job.
I remember watching the twin pyro set-up in Pier's truck. The pre turbo reacted very quickly to throttle (fueling levels) position. The post pyro was more stable but was being buffered by the mass of the turbo housing. It was enough to make me change mine from the post turbo position. How long can you afford to wait for a high temp reading?
Sleeper
98 QC 2WD 5 Sp 3. 54 BD Mods: K&N, #11 plate, 16cm, 4" back from gutted cat. 340 RWHP
