They're way noisy, and I just have to say (as with all things like this and bypass kits) that when you add extra lines and fittings to the lifeblood of your engine, you're adding extra chance for leaks and ruptures to occur. The hose that feeds your turbo is enough of an appendage for me. There's also one on the injection pump. I've seen these engines with up to 800,000 miles on them and the particular one I'm talking about didn't have a preluber and it was running in-spec compression. I don't see the need for it unless you don't plan on using it for weeks at a time. I have a preluber on my engine--the starter. I wired my shutoff/run solenoid to a toggle switch as an anti theft device, and to prelube after a weeks' vacation or so, I keep the switch off and crank the engine for a few seconds until I see the gauge move. Engine is prelubed, safely, without the dangers of combustion on a "dry" engine.
Chris Timochko
1997 5sp 4X4, HX40, BD 4" Brake, Marine Compression, Custom Tuned Injection Pump, 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, Water Injection, NOS Diesel Kit, 6" Chrome Exhaust System, No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc, Goodyear Wrangler AT/S 305/70/16s. Test mule for Auto Wurks Diesel race program
