Friday May 24, 10:48 am Eastern Time
Press Release
SOURCE: Premo Lubrication Technologies, Inc.
Premo Lubrication Technologies Announces New Program to Help You Extend Your
Oil Drain Intervals and Your Engine Life
TAMPA, Fla. , May 24 /PRNewswire/ -- Premo Lubrication Technologies, a leader
in engine and hydraulic oil filtering systems, announced today a special
promotional launch of its PremoPlus oil by-pass filter systems which utilize
an advanced, high performance 3 micron absolute filter media pack
(Ultipor)(TM) which is rated B>200 (removes 99. 5% of all particulates 3
microns or larger on each pass of the oil through the cartridge) designed by
Pall Corporation, a leading edge supplier to the filtration and separations
industry.
Premo Lubrication Technologies will supply the following:
1 PremoPlus LT30P unit, complete with Pall Ultipor(TM) III synthetic
filter media cartridge,
2 PremoPlus Pall Ultipor(TM)(O) III filter cartridges,
6 oil analysis kits,
1 pressure regulator,
1 special drain plug,
1 inlet hose,
1 return hose,
1 installation video, for only $499. 99 instead of $791. 00. This is a 40%
savings. (Limit 3 units)
According to the Company, oil changes will be 3 to 4 times less frequent
than without this system. The new filter design will provide not only
improved cleanliness, but extended filter service life even under harsh,
high soot- level engine lube system conditions.
The new PremoPlus oil by-pass system features a proprietary Pall filter
media design that captures 99. 5% of all particles 3 microns or larger
(Beta>200). This improvement results in downstream multi-pass cleanliness
levels over 2. 5 times cleaner to provide enhanced protection against soot
build-up in diesel engine lube systems, especially when compared to
traditional engine lube filters that are "nominally" rated between 30 and 40
microns. The PremoPlus filter also features a unique, tapered pore media
design that gradually spreads contaminants through the full depth of the
media to prevent blind-off and premature element plugging. After filtering,
the PremoPlus system heats the oil to 195 degrees F in a separate chamber to
vaporize and vent off any liquid contaminants remaining in the oil.
The improved filtering and re-refining process, when used in conjunction
with routine oil analysis, can dramatically extend diesel engine lube oil
service life. Instead of an oil change, simply spin-off the Premo 3um
filter, spin-on a new one and top-off with 2-3 quarts of new oil... . not the
48 quarts normally needed for a Class 8 truck oil change. Also, following
the recommended filter change frequency of 20,000-30,000 miles on the Premo
filter (and 75,000 miles for the engine full flow filter) saves additional
maintenance costs and downtime. Finally, running with clean engine oil every
day, every mile can extend vehicle life, providing substantial savings in
reduced fleet acquisition costs.
About Premo Lubrication Technologies
Headquartered in Tampa, Florida, Premo Lubrication Technologies is one of
the leading developers and manufacturers of electric oil re-refining systems
for engines and hydraulic oil. Its premier product, the "PremoPlus" Electric
Oil By-Pass Filter System is the most advanced filtration technology on the
world market, extending engine and hydraulic system service life and
drastically reducing oil use and disposal costs. For more information go to
http://www.premolube.com or call 800-875-8751.
About Pall Corporation
Pall Corporation (NYSE: PLL <http://finance.yahoo.com/q?s=pll&d=t> - News
<http://biz.yahoo.com/n/p/pll.html>) is the leader in the rapidly growing
filtration, separations and purification industry. It provides leading-edge
products for use in high-growth applications such as genomics, proteomics
and biotechnology; in transfusion medicine, semi-conductor, water, aerospace
and a host of other industrial industries. Pall's business is organized
around two broad markets: Life Sciences and Industrial and has annual sales
of over $1. 2 billion. The Company is headquartered in East Hills, New York
and has operations in more than 30 countries. Further information is
available at http://www.pall.com .
Press Release
industry.
1 inlet hose,
1 return hose,
