Pulled the visor off, ground away the rust, filled the rust holes and bolt holes, sanded most of the second paint job and some of the original paint off, ground off the mounting pins for the ding strips, welded up the cracks in the bed corners near the tailgate, and have it ready to prime Monday. Then 3 days of block sanding before sealing painting and clear-coating. Trying to finsih within two weeks!
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N air filter, cleaned-up exhaust, Dynomax straight-thru, rebuilt pump, 12cm wastegated turbo, thermostaticly controlled twin 14" electric fans, intercooler, modified 518 OD transmission, Gear vendors OD controler, R-134, louvered fenders, 93 aftermarket smoothe grille; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. Jesus saves!
