Pressing bearings together?
Exhaust brake information
Running boards
When I was removing the the hub today, the bearing separated in half... Luckily, everything else broke loose at the same time. Is it possible to press the bearing back together, or will I be calling skf tomorrow?
Thanks,
Jake
We've had this happen... . we wire brush the frame of the truck and the back of the bearing so that it's clean... we than wash the bearing set and repack them with grease and then put them in an arbor press and push them back together... one of our trucks now has close to 100K miles since it was apart for u-joints and greasing the bearings... .
We use a liberal coat of anti-seize on the parts that fit together so that when we need to pull it apart again... . we won't have to pound on it...
Hope this helps.
