Here is a list of things I tried thus far.
This problem started a month ago while driving my truck started to stumble, looked at my fuel pressure gauge and it was at 0, was able to get home and thought the lift pump failed so I replaced it and truck had good pressure but dropped off to 0 while running truck that's when I called a mechanic. He thought the pump was shutting off for some reason so wired it up to the ignition switch, still doing the same thing. Replace pressure regulator, same problem. Dropped tank installed jeep module, no luck. Replaced fuel line from tank to pump, removed lines from lift pump to VP44 and cleaned out, same problem. Pulled fuel filter housing and found metal pieces I the heating element cleaned that all out reinstalled and same problem. by passed fuel filter, ran line to LP from a fuel can,when I turn the ignition on the pressure reaches 15 psi and stays there, Once it is running pressure drops to about 9 and each time I rev the engine the pressure drops and drops and drops till we're at 0, At that point engine starves and stops
