PressureLoc install / gauge
New Website
Banks vs TST
After I get my BD Torque Convertor and valve body installed July 5, I'm going to install their PressureLoc. Instructions say I need a 250 lb. gauge for making adjustments. What's the procedure? Rig the gauge into the cab as a temporary or do a permanent install to keep an eye on it?
Any problem hooking up PressureLoc with a "mystery" switch installed?
Any other suggestions on the install?
Dan Heynen - Anchorage - '97 Club Cab 2500 4X4 with most of the whistles and bells, Auto, 3. 54, US Gear Engine brake, gauges, K&N air filter, lock-up switch, TST 230hp Power Kit , Mag-Tec rear differential cover, Bushwhacker fender flares, NorthWest Custom rear fender flaps, Rhino spray in bedliner, Amsoil user and dealer, 28 foot Cardinal 5th wheel, 25 foot Ericson sailboat, Western Pro Plow, Arctic Cat snowmobiles.
Dan. . learn from my mistakes, 1st the gauge can be a 150psi gauge i purached one from mc-master carr... they are online too. you need to check the pressures before and after the mods to make sure it is performing right,I had a mechanic buddy help me install it,We use a plastic hose and hose clamps and discovered this was the wrong way. When we took a test ride the pressure loc kicked in (120)psi and blew the line or hit the exhuast and spew transmission fuild (Amsoil ATF 4. . for your other post... i like it)all over. . lucky my friend heard it and i shut it down. We got under there and fluid was everywhere(am still cleanin after 3 weeks. . heheh) Smart guy he is,he brought the plug and extra transmission fuild (you da man bill)... Put the plug in. . added 2 quarts and we were on our way. I got home and robbed a 1/8 pipe to -04 fitting and some -04 stainless braid line off my mustang and have been driving around with the gauge under the windsheid wiper arm for a couple weeks jus to see what the transmission is doing... . one more hint... the spring is a PITA to adjust, i ordered 2 spares since i over-stretched mine ... JB
99 Quad,Long bed,4x4, SLT,Auto,K&N,Mobil Super Delvac 1300,fuel line up-grade from lift pump to filter and from filter to injection pump, Suncoast coverter,BD valve body and pressure-loc,Mag-Hytec trans pan,Amsoil ATF-4,Auto meter Ultra lite gauges:Boost,EGT,Fuel Pressure,Trans Temp, "true" Jet-Hot Coated 5 inch exhaust from turbo to tail pipe(over the axle)Borla shoot-out muffler,DD stage 3 injectors and boost module,HX-40 16cm,here and waiting to fab-up a a new adaptor,Next Jet-hot the exhaust manifold and turbo housing,..... finally a blue box or TST box or?????
[This message has been edited by QuadDoorRam25004x4diesel (edited 06-23-2000). ]
