I installed a FASS HPFP on my truck this weekend after the old lift pump started heading south. Along with the pump, I put in a draw straw and new lines. Everything is running fine, but now my tank is pressurized. I drove from my house to work this morning (about 6 miles), and when I shut the truck off I could hear a hissing sound comming from the tank. I opened the fuel cap and the pressure almost blew it out of my hand. It seems like it is way more pressure than the pump is capable of. I should also mention that this morning is the first time I filled the truck since I installed the pump.
I did a search for old posts, and found quite a few. It seems like replacing the copper washers on the injectors fixed the problem. My question is where can I get a set of washers, and how hard is it to replace them. Does anyone have any other ideas as to what could be causing this?
Thanks,
John
Thanks,
John
