Price Check for bearings and u-joints
D
Replace control arms or just the bushings?
rear rotor help
Anyone have a ball park figure on what I could expect to pay for both front wheel bearings and front u-joints for a 2004 3rd generation 3500 Ram Dually?
Welcome to TDR, I think you can get a quality bearing for about $250 each and about $65 per u-joint. If you are wanting a ballpark for labor I would estimate 6-8 hours since it has wheel spacers. Be sure to check the condition of ball joints and brake components while your going to be there.
Matt
Matt
Thanks for the response Matt. Looks like more work than I am capable of handling, so I will be looking for a place to get this checked out and done properly. Thanks again.
you might consider using or at least checking a company called rockauto.com... you'll find parts that are available from several different manufactures... if you search hard... you'll find some really great prices...
Hi Blue Duck, you should fill out your signature and where your at so we can let you know of a good shop to do the work. Many times a good referral can save you troubles.
Thanks, I may just do that although I may be able to get some of the parts from the dealer. I still have 30K miles left on warranty. I don't like the idea of installing OEM instead of greasable but it is what it is. Thanks for the reply.
I don't believe I can fill out a signature yet as I am not a full member at this time. I will do that as soon as I can. Thanks.
Geez... if you are still covered by warranty on your truck... by all means go and let the dealer do the work... Lets see... NE OR, Hermiston, Pendleton, La Grande, Baker?
If you have the 515089 hub on the front of your truck... contact me by email and I'll give you a lead on some great pricing...
