The easy way to clean the filter if you do not have the proper cleaning solvent, would be to spray Heavy with Simple Green. Let the simple green soak in and do its thing for about a minute, and rinse throughtly ( not pressure wash) and repeat if necessary. Allow to dry outside in the open sun, turning it say every 15 minutes or so, get all sides drying ( do not put in Mirco wave, oven or use compressed air ) as this may damage the filter element . This usually takes about an hour. Spray a light oil, or what I use is the K&N oil and let soak into the fibers. Do not over oil. Maybe another 1/2 hour or so, re-install. I usually do this around every 15,00 miles or whenever it appears dirty. I do this when I do other servicing, such changing oil, differential, trans etc. Buy the time you finishing doing other servicing your filter cleaning and re-install is also done.
