Lt, Just installed a prob today. All I do is insert my little finger (pinky) into the exhaust manifold and push the prob down until it pushes against my finger. Kind of like a feeler gauge. Making sure you have a drag on the finger while pulling it out. Not real technical I know, but I have done it this way for years and never had a problem. Also make sure not to over tighten the compression fitting as it will render it usless for pulling the prob out again without taking the whole fitting out. It will not take much, just so it does not slide up or down is all you need to accomplish. I always drill and tap two holes as long as I'm doing it. Just plug the other using plenty of high temp anti-sieze.
'89, CC, SB, 5sp, 3. 54, 16cm2 housing, maxed fuel, KN, Banks exh w/muffler, Autometer liquid filled gauges, Factory tach option, Horton fan clutch, Firestone air bags, Chrysler V-twin air comp, 100% Dyna-Mat, 2. 5" lift, Rancho Shocks, Alcoa LTS, BFG 255/85/R16 MTs (33. 5")
[This message has been edited by Stab (edited 01-19-2000). ]
