Engine/Transmission (1998.5 - 2002) Problem Banks E Brake....Help
Engine/Transmission (1998.5 - 2002) code p0071
Engine/Transmission (1998.5 - 2002) Oil analysis results
I just finished installing a Banks exhaust brake on a 02', 6 speed, 4x4.
The E brake works flawlessly. The problem is that it set a code and a the check engine light is on. The codes are 1693, P0501.
Has anyone else experienced this problem . I won't be able to call Banks untill wednsday, so any help or advice would be appreciated :{
Thanks :D :D
David
__________________
02, Ram 2500, HO, 6 sp, 3. 54, L/B, 4x4, Bright silver, SLT.
To much fun !!!
P0501 Vehicle Speed Sensor A Range/Performance that is the generic description of that code
this is what i could find on the other code
41TE, 42LE
Code P1693
The Definition for Code P1693 is Companion Module Failure. It is necessary to check all
other modules for codes or failures. This is NOT the same as code 45 TCM. Most publications
DO NOT list this code or list the wrong definition. It is not uncommon for technicians
to replace the TCM when, in fact, it’s usually a problem with the PCM.
did you tap any common refrence voltages? maybe at the map? i havent installed any of these so im not sure what they tap into.
jamie
mrpeal said:
This is what i could find on the other code
41TE, 42LE
Code P1693
The Definition for Code P1693 is Companion Module Failure. It is necessary to check all other modules for codes or failures. This is NOT the same as code 45 TCM. Most publications DO NOT list this code or list the wrong definition. It is not uncommon for technicians to replace the TCM when, in fact, it’s usually a problem with the PCM.
jamie
On the Dodge Ram with the Cummins, PCU - P1693 is a companion code, and all it means is that there has been a code set in the ECU, Nothing more, no reflash, no reprograming, no software update needed, and unless the other code is ECM/PCM (ECU/PCU) related, there is no failure with the PCM (PCU)
