I have a clunking noise that I can't determine the source. The only way a can describe it is it sounds like I'm still locked in 4-wheel drive. I can only hear it when I'm making slow left or right turns in a parking lot. In 2x and 4x. I hear it when turning in gear and in neutral. I've check all u-joints, seems o. k. There seems to be a little play on the passenger side wheel bearing, but so slight I don't know if I felt it correctly. The steering stabilizer was leaking so I replaced that thinking it was the cause. Can still feel it with it on and off. Everything is well greased and can't see anything that's binding. Thank you for suggestions.
Paul
Paul
