Okay, here's the problem: I put on the shell late last week, and when I hooked up the 3rd brake light, I ran into a problem. I had the guys at the shop take a look at it also, and it is hooked up the same as all the others they have done: power from the main power lead on the left-rear brake light (labeled "Main"), and we ran a self-tapper to be positive that we have a good ground... all seems to work well when I put on the brakes, but if I hit the left turn signal, the 3rd light flashes with the signal. So we wired it up to the right taillight, and the same thing. I don't understand why there is power going to the 3rd brake light when the signal is on, there shouldn't be.
We are tapped into the brake lead, not the signal lead... when the brakes are on, the light works well, but if I use the signal at the same time, the light goes off and begins flashing.
I have replaced the flashers in the fuse panel, I am about to replace the actual brake light/signal/bulb assembly, but I am reluctant because it was the same on both sides of the truck. (I thought that maybe there was a problem in there, sending a pulse back with the turn signal, but I can't imagine both of them are bad)
Any ideas as to what I am doing wrong?
