Vaughn MacKenzie
Has anyone done the Luke's Link then had trouble with it popping soon afterwards? Mine did and a little investigation revealed all the popping is occuring at the axle end of the bar.
I replaced the OEM rubber bushing with the poly one that came with the kit, but it acts like the bolt hole is too big or something. The track bar snaps back and forth while someone turns the wheel with me watching underneath. The bushing fit in nice and tight when I put it together, and the bolt seemed tight in the hole, and the bolt holes on my axle bracket aren't pounded out, so I don't know what's going on.
Cummins4Life did his trackbar and he's having the exact same issue. The bolt is torqued to over 100 ft/lbs but regardless the bolt should be tight in the hole with no play or slop. I am going to see if I can locate a new bolt with a shoulder the full length of the hole.
Vaughn
Vaughn
