problems with DTT transmission
A bunch of general questions.....
Adding keyless entry, difficulty / expense?
Anybody with the auto thats had these problems please help! Im sitting at 5. 17 volts right now at the pcm. My regulator is bad because im reading a little under 12 volts right now and I cant adjust it. Ive tried the 50, 100, 150 ohm resistors and even tied 3 together to get 300ohms and it still will not drop below 5. 17. What do I do. I cannot get ahold of Bill K. And also what watt resistors do i use. i have 1/2 watt now
check out these links(past threads)... they maynot have the direct solution/info, but you can see what TDR members did the same work. . you can email them directly and ask. . thats what I would do.
http://216.235.147.117/forums/showthread.php?s=&threadid=11678&highlight=DTT+transmission+resistor
http://216.235.147.117/forums/showthread.php?s=&threadid=11630&highlight=DTT+transmission+resistor
This one has a reply from Bill:
http://216.235.147.117/forums/showthread.php?s=&threadid=1018&highlight=DTT+transmission+resistor
http://216.235.147.117/forums/showthread.php?s=&threadid=10144&highlight=DTT+transmission+resistor
http://216.235.147.117/forums/showthread.php?s=&threadid=10106&highlight=DTT+transmission+resistor
http://216.235.147.117/forums/showthread.php?s=&threadid=9725&highlight=DTT+transmission+resistor
Well figured out what it was. . some water got in the regulator and laid acroos the curcuits. That explained why I was getting 12 volts out of the orange wire. What a day. :mad: But thanks to Turbo Terry he helped me figure it out.
