Hi all,
I was on my way home from Denver tonight and stopped to check out a classic Power Wagon at a gas station in Castle Rock. Come to find out, the owner was broken down with filter problems on his 12V. Turns out, this wasn't the first time and I asked him if he was a TDR member. He wasn't but reads the forums so I thought I'd ask the question for him.
Has anyone had a catastrophic failure of a NAPA Gold filter? Two separate times, the filter housing itself failed, causing a massive fuel leak and shutting down the engine.
The first incident was a couple of months ago when the filter housing split at the top outer edge where it is folded over and sealed to the mounting surface. The second filter housing had 15K miles on it and cracked on the bottom where the bung for the water drain is welded on.
Now to NAPA's credit, they gave $100 in store credit to him for his trouble the first time so at least they made it right, but I'd just like to know if anyone else has had trouble like this with a NAPA filter as I'd never heard anything like this before. I'll keep you apprised of the outcome of the second incident.
Oh, and David, I hope you made it home to Cheyenne safely with no further problems and hope to see you on the TDR soon.
Later,
Joe
Later,
Joe
