JWChessell
My Prodigy brake controller intermittently shows "S. H. " (Short) while towing in the rain -- this has occurred on the last two trips. Braking doesn't seem to be affected however; step on brake, S. H. code disappears and trailer brakes normally. This does not occur at idle, but at 60 MPH. Am also getting "n. c. " (not connected) code under same conditions. But trailer still brakes normally when pressure applied to brake.
Have any of you experienced this problem? Is there a cure, such as electrical grease in all the contacts of the trailer wiring plug? Could the problem be elsewhere other than where the male trailer plug meets the female receptacle on the truck's rear bumper?
Thanks.
Thanks.
