Welll like the title suggest, I finally got to install the Amsoil remount dual By-pass filter mount I purchased from them. I did not go with the kit, I wanted a different engine adapter then their cast aluminum one, and I did not want the mount located in the engine compartment, it just makes things to conjested.
I got the engine adapter from John S, a fellow TDR member that makes a great billet aluminum piece, it's way cool and the best I've seen. One twist i had to work around was, both the engine adapter and filter mount came with 3/4-16 O-ring fittings to 3/4JIC(An #8), I wanted to use An # 10 hose, so I had to source the neccessary fittings, which took some time. I liked the larger hose because I wanted to make sure there would be no pressure drop or flow restriction, I plan on mounting the filter mount up front behind the bumper.
I did not like the popular option of mounting the filters in the engine compartment, yes it is closer, but makes the engine compartment way to cluttered. I also do not see how people can use the battery hold down stud as a secure mount for the filters, it is just not strong enough, my opinion. I went up front behind the bumper on the passenger side, I have the Buckstop bumper and there is plenty of room behind it for the mount. Fabricated a simple but strong piece to hang the filter mount off of and secured it to the bottom using one of the brushguard studs. For the lines I used Russell #10 stainless steel hose, along with their fittings and swivel hose ends. I also used two layers of shrink tube on the sections where they come into contack with other hoses and wires, this will keep them from chafing the others.
The whole thing went pretty smoothly, I haven't made up SS line in some time, felt good to be back. I also installed the new AmsOiler, it attaches to the filter mount and pre lubbs the engine with a shot of captured pressurized oil before engine start up. They did a very nice job designing the piece, it fits nicely on the back of the Amsoil filter mount. Wiring is complete and very simple, just need a grond and a hot when On terminal. When you go to start the engine, a small buzzer sounds and lets you know the Oiler is working, then just start as normal. I had the old and unreliable Pre-Lubber from years ago, this is nothing like that and works by storing the engines oil while under pressure, very clever and simple.
I made a few pictures of the parts and pieces it took to do the job, later i will get a picture of the unit installed. Anyone thinking about adding something like this, don't worry it is very simple and easy to install.
