I used the Power Shot 2000 setup on my '91, and it worked great - other makers have copied most of Keith's features, but his is still best and most reasonably priced in my opinion.
BUT, now I have the new truck, and have removed the propane setup from the old truck, expecting to install it on the new one after I get a few more miles on it for warranty purposes. PROBLEM is, it SEEMS as tho hardly anyone is using propane on the later trucks, and I don't know if it's due to unusual problems with the later 24 valve engines, or whether it's just the accepted fad now to simply go for the various "magic boxes" instead of propane.
I recognize the potential dangers of propane use if abused or improperly set up - but that's really not all that different from other more common power-enhancing methods, and I'm unsure if the later engines might be more sensitive to propne injection than the older ones?
Sure would like to use the propane on my new truck at some point - but certainly don't wanna cause problems if there's some unique problem associated with propane in the newer engines that I'm unaware of...
I've done a search on the subject, as it applies to the newer engines - but haven't really determined anything specific as to why or whether propane is/is not used as much on the later engines...
Any comments?
Any comments?
