Originally posted by K_Arts
jrandol - Geesh buddy, That HP bug is really bit'n isn't it??![]()
Don't let the wife find out. . LOL
I installed a two stage propane system about 3 months ago. This particular system is a bleed system only. 5. 5 gallon will last me about 1100 miles. I am seeing about a 1. 5 to 2 mile per gallon increase. By using a bleed system, it is enough propane to act as a catalyst that helps supplement the oxygen in the cylinder. As far as power, maybe 5 to 10 horse. There is a slight gain but not much. This particular system is pretty neat in how it operates. The supply tank can be either liquid or vapor. If using liquid the unit will vaporize it and send it on. I elected to use a vapor tank because in order to get the size tank that I wanted. All that was available was vapor. The unit's electrical system is set up with some good safeguards. There are 2 power feeds. The main feed is ignition (key on). The second is a field wire that I connected to the alternator. It will only energize when the truck is running (alternator producing 12 volt current. ) This prevents any kind of build-up of propane in the air intake system.Originally posted by Mundgyver
I thought that propanes big claim to fame besides some HP was that if used in economy mode, you would get enough additional mpg to more than pay for itself. My understanding is that a very small amount causes a more complete burn of the diesel.Can anybody out there shed any light on this.
Originally posted by jrandol
Yep, the wife would flip right now if she knew what I have in store. Gonna have to get after my Sales Reps. to kick some butt so the bonuses will pay for my new found addiction.transmission comes next cuz I dont know how longer I'll be able to be good with the FMS and not add to much fuel. Certainly mixed opinions about Propane, pretty sure not the route for me now. My stock little turbo needs to go pretty quick after the transmission. Ah... . horsepower is such a dangerous thing.
Originally posted by sticks
jrandol, you need to pace yourself. Maybe you should get some help. I'm sure there is a 12 step program available for the TDR BOMBing members![]()
You have gone from bone stock to this in less than a three weeks.
Hi, I am Jeff... . And I'm a Diesaholic
Kinda has a ring to it, dont ya think?
