I changed mine yesterday. Can't vouch for proper, but it worked great!
Prior to start get yourself about a quart and a half of fresh diesel, check your new filter and make sure that it is complete with a new small "O" ring.
1) Take 1 gallon zip lock bag.
2) Disconnect WIF (Water in Fuel) sensor front lower of canister.
3) Put zip lock over canister, pull it up as hich as you can.
4) Unscrew nut in the center top of the canister.
5) Keep your hand under canister so that it dosen't fall away.
6) When canister is disconnected, make sure that filter comes off with it. I am told that getting the filter off before any siphon action occurrs is good.
7) Close zip lock, take the whole thing out. Won't spill much diesel ths way.
8) Take the smaoo "O" ring off the center post.
9) Take the filter out.
10) I dumped the diesel in a 1 Quart empty oil bottle and sealed it up.
11) Clean out the canister very well.
12) Fill the canister about 3/4 full of clean fresh diesel.
13) Gently insert the new filter. Hopefully you won't overflow.
14) Put a new small "O" ring on the center post.
15) It helps here to put the canister inanother zip lock.
16) Gently put the canister in place and tighten. (10 Ftlb)
17) Remove the ziplock, reconnect the WIF sensor.
18) Turn the key on, wait till "Wait to Start" goes out.
19) Gently "Bump" the starter. At this poing mine actually started up and ran like it should.
20) You can repeat steps 18 & 19 as needed.
21) Check for leaks.
The 24V should be self purging. Mine always has.
Disclaimer below.
From my own experience. Sanctioned only by me.
