Rebuilding my engine after what appears to be an unfortunate incident with a stray washer. I had it bored 20 over and got pistons and rings. The piston clearance is about . 015 thousands which I think is right. The rings are a bit of a mystery
Spec Actual
Upper ring . 035 to . 045 . 055
Middle ring . 085 to . 115 . 045
I know I can file the middle ring larger, but wondering if the upper ring is OK. Oil ring measured good too. Essentially the same on all 6. Mahle/Clevite.
Your help would be appreciated.
Dennis
Spec Actual
Dennis
