Proper tie down method
Pine Sap
What suspension mods will I need?
I have been help a couple of friends in landscaping hauling rented equipment. Most of the rental centers tie down the equipment (skid steers, rollers, excavators) with a single chain front and rear and one binder.
Is this a safe and legal method?
I thought each corner needed a chain and binder with a working limit equal to or greater than the machine weight.
In sunny CA you have to have a chain at each corner, but only need to bind on two, usually front or rear, and if using binders instead of the ratcheting ones, I think you have to have enough chain to wrap the handle so it can't pop free. Not sure on the last part, but I do know its a good practice, law or not. Check with your local Highway Patrol Office. Just give them a call, they should be happy to send you down the right path.
You are correct, if you want to be legal. On a backhoe, in most states, legally you need 5 chains. One in each corner of the hoe and one to bind the rear bucket down. Like Diesel Nut said, it's good practice to bind the handle with the chain itself, any kind of wire or even tape. We haul alot of equipment and are frequently checked by DOT. If they don't like what they see, they can and will make your day VERY long and expensive.
