Engine/Transmission (1994 - 1998) PS hoses go where again???
Engine/Transmission (1994 - 1998) 60lb valve springs
Engine/Transmission (1994 - 1998) Starter Solenoid Rubber Plug
98 12v
Can you point me to a Diagram or detailed instructions for where VP/PS hoses hook up to?
took it apart a while ago, 2 PS pumps returned for defects and waiting for 3rd
Now I'm not sure about the hook up!
Also did my KDP, can I reassemble everything in front end except the drive belt before reinstalling my VP/PS pump? Or will it be much easier leaving the front stuff off... seems like it won't make a difference and I could get something done while waiting for the pump (should be here next day or so)
I know where some hoses go but would like complete info and confirmation
thanks
I wont have time untill at least Saturday 16 hour work days dont leave much daylight time but I'll snap a few when i get a chance
I found pics of my hydroboost setup, so my truck is stock.
Installed the vp/ps unit because I'm antsy to get done. put hoses on the PS pump and just need to find where to connect them to...
Here's a pic of my ps pump installed
and a pic of my hydroboost/mc
another trying to show how my lines go in the steering box--but battery cable in the way. . but there's a supply line and return line pressure fitting in the box
the last pic is generally of the engine compartment...
So the 2 lines by the master cylinder, one supplies the steering box, the other returns from steering box
In between is a metal line that I believe is the PS return line?
So it just has a clamped hose from a PS pump barb clamped to that line?
That leaves where on the hydroboost does the pressure line (supply line)from the PS pump connect to hydroboost
and where do I look to connect the other PS barb?
thanks, I'm waiting to hook these up and then I'm done...
I just re read the post and realized you got that crazy hydro boost stuff for the brakes, which my truck don't got. I did go out and take the pictures if you still want em but I dont think they are gonna do you any good. Sorry... .
OK, I found the diagram for my truck, and man I had it all cattywampus, so thats why I couldn't figure it out.
I'll post the diagram (which is very clear)
in case anyone else ever makes my mistake.
Thanks Kenny61 for the support, now I'll get it done.
