I have been working on the replacement of the original steering box on my 2000 3500 DRW. Along with the Borgeson Steering box from Geno's Garage, I replaced the steering shaft, both high pressure and return PS lines, rebuilt the vacuum pump and subsequently replaced the PS Pump with the Borgeson pump, also from Geno's.
I followed all the directions for bleeding the air from the PS Pump and related components from Borgeson and the factory manual. However, no fluid would pump from the PS pump into the Hydroboost system, thereby preventing fluid from even getting into the steering box. After reading several forums on the TDR, I found one that indicated the pressure relief valve in the PS pump needed pressure to open and allow fluid to pass. So, I followed the directions and increased RPM between 1500-2000 and presto! I had power assist to my steering. I then do all of the sequence for steering lock to lock and add fluid as needed. PS system is now working great....and then...
I have the wife come out and begin steering from lock to lock with and without the motor running so I can complete leak test and check for any potential clearance issues. Wife is in the middle of steering back and forth and the truck suddenly increased RPM without any pedal pressure to the throttle. My wife's first response was, "I didn't touch the gas!" After correcting her verbiage of her denial of any "throttle" application and she finished glaring at me, finishing with an eye roll, I had her shut the truck off.
I hop in and with the engine running, begin to steer from lock to lock slowly. I was able to get the RPM to increase randomly at different quantities without any rhyme, reason, or pattern.
What the heck happened? Is there a new problem, or is this "repair" I am trying to complete manifesting into something else?
Meanwhile, I am still driving the neighbor's 2018 Eco-Diesel....while mine sits on jacks stands in my garage.
Any ideas?
Any ideas?
