Psychotty air and air compressor
headliner
Hissing noise under boost
Is anyone doing anything with the space that was used by the old air filter housing? I just had a piece of 1/4" aluminum cut to fit the area. I mounted it on the original three studs with rubber washers. I then mounted my air compressor (for air horns and an air up system) on the plate along with the SOV and pressure switch. Looks very nice, it's protected, and easy to get to. Just hope the heat will won't be a factor. Just thought I'd share...
98. 5 2500, 24v, 5 speed, QC, 4x4, 4. 10 LSD, short bed, Line-X liner, tow package, camper suspension, Westin nerfs, camper shell, TST PowerMax Competition, 275 RVs, Psychotty air, HX-40, 4" straight pipe exhaust, ProComp A/T 305/70/R16s, EGT/Boost pillar gauges... Love my Cummins, no love for Dodge
I got a heat shield form Jannetty Racing that mounts to the exsisting studs from the airbox. It is basically a wall between the turbo and the air filter. Seems to be pretty effective
Vaman, good idea. Adding a Physcotty and dumping the airbox really frees up a lot of space. I still haven't decided what to fill the space on mine up with yet.
The space in mine will be used to hold the bottle for my water injection system this summer.
EAT'M UP
97 2500 Club 4X4 3. 54, Forrest Green/Driftwood, LSD 5 speed, & Psychotty Air System, TST #11, 370 HP injectors, timing at 16 deg. , 16CM2 housing, AFC spring kit, TST EGT gauge & 0-60 boost gauge in A Pillar, Cat-be-gone, 4" Dynomax Bullet muffler, Crome 4" turn down, 2 Electric Fans, One inside/ One out front, AmsOil Through out, Geno's trans filter kit, AmsOil Bypass system, Lund Winter front, Leer Cab Level Shell Driftwood , 255/85R16, South Bend's Hypo Clutch*NRA/USPSA member and proud of it*
Since I have the Jacobs e-brake,I mounted the vacuum solenoid in the old airbox space. Still have room for other things.
-Mike
