Installed my PSA two weeks ago and this is what I have found. On level or slight hills (4% grade or less), EGT can barely hit 1300 at WOT before dropping as boost comes on. Previously my truck would hit 1300 and climbing if you did not back off trottle. Towing a 3K trailer up a long steep hill, (8-9% grade)with O/D on, EGT will hit 1300 at 55 mph, but can be maintained at under 1300 be regulating speed with your foot. Previously, EGT would hit 1300+ at 48 mph and then you could not keep EGT under 1300 with out turning O/D off. I can leave the O/D on all the way to the top of the hill now.
Installation was simple, thanks to Big E loaning me his hole saw. Changed from Scotty to Psycotty in under an hour, including taking out tools and putting tools away.
Noise, what noise? Some complained about a "whistle. " I did not find the sound of cool air being sucked into my engine intrusive or bothersome. In fact I wish it was louder. Occurs only during acceleration. Once I am at cruising speed,
I don't hear it. Maybe my exhaust is TOO LOUD.
My conclusion: It definitely reduces EGT a significant amount. Allows you to WOT longer. Is it a worthwhile installation? Yes, definitely.
1996 3500 Clubcab SLT, auto, 4. 10 limited-slip, TST #5, Psycotty Air, Dunrite converter, Trans-Go shift kit, Straight pipe, DiPricol EGT, boost & trans temp. gauges, 9 ft. aluminum flatbed and tool boxes with Venco dump. Custom front bumper, Hadley air horn.
