Does anyone know the specs of what kind of PTO we can hook up to the PTO ports on the NV4500? I know it's a "6 bolt", but apparently, you need to know whether it's a straight or helical gear and what gear pitch or some such. This makes a marginal amount of sense to me, but never having done any PTO work, I'm not really sure what I need to know.
I'm working on putting a PTO powered air compressor on so I can run air tools when fixing broken tractors/implements out in the field. Little pumps like the quick airs, etc. probably won't cut it (sometimes I need to run a *HUGE* 1 inch impact gun for those big 2+ inch nuts at 900+ lb-ft torque... Hmmm, even the mightly Cummins doesn't do that
Anyway, I can get the PTO adapter for $50 if I know what I need (from a local truck junk yard). Then, all I need is a tank (probably from the same junk yard) and a compressor (yet to be figured out) and stuff to connect them together. I'll post complete info on how the project turns out when I get it done.
-cj
-cj
