Engine/Transmission (1994 - 1998) Pull engine out for head studs?
2nd Gen Non-Engine/Transmission front axle shafts ???????????
Engine/Transmission (1994 - 1998) Cummins 5.9B Compressor?
To do a proper job of new head gaskets and head studs for be able to hold 500+RWHP... do you have to pull the engine out or lift the body at all?
Nope, Theres plugs in the cowl to remove them without pulling the motor or lifting the body. Probably the best dam thing Dodge engineers did on these trucks... .
Ditto on Signal reply. That is if you stay with 12mm studs. If you go to 14mm studs you have to tap the block. I don't know if they do that with the block in the truck or not. I went with the 12mm since I didn't think I would get to the level requiring 14mm.
thomas
Either get the ARP's or I think Haisley's makes theres with the bosses in the ends now so you can use a socket cap to screw them in... ... ... this makes the job about half as hard as the old double nut method like my 14mm's.
Jim
