My truck is pulling slightly to the right. The crown of the road doesn't seem to be causing it, because it will do it if I drive right down the center of the road as well.
The dealer aligned it this morning, and the only thing out of specs was 1/4* of right side toe. It is now set back to Chrysler specs and is still doing it.
I switched the right and left front tires to see if that would switch the pull, and it did not. Tire aire pressures are equal side to side.
Does anyone have any other suggestions? I'm thinking about taking it to a top notch independent shop in town to have them look at it.
Everything is all stock except for BFG All Terrain T/A tires. 12,000 miles on the clock.
