There was nothing there a week ago when I pulled the sample
Not necessary if you know how to read a report. High sodium and potassium with water. Pretty obvious. Monitor isn't the only labs that don't list coolant.This is why I prefer to use a lab that tests for coolant. That report wasnt even flagged.
He doesn't have high potassium or sodium levels. That's already been established. Remember, my levels have been higher, with zero water or glycol?
Those aren't high numbers at all. I don't know why your fixed on that.
Water is tested using a solution of alcohol and iodine and reacts much differently than glycol, it's not an accurate method to use to determine antifreeze.
That's why I asked how you took the sample. If the oil was still hot when you pulled the sample the coolant may have been mixed in well enough you didn't notice it.
When you shut the truck off and the coolant has a chance to separate from the oil is when you will see what you witnessed.
Maybe whatever let go punched a hole internally and its been leaking ever since?the strange thing is I took the sample cold the truck hadn’t been started in about a week and the oil was black as black . Now the truck has probably sat two weeks and magically there is that much antifreeze in it ?
Pulled the sample cold engine hadn’t been ran for a week or so that’s the thing I can’t getYou pulled the sample from the bottom? Was the oil ambient temperature or was it warm when you took the sample?
Anything is possibleMaybe whatever let go punched a hole internally and its been leaking ever since?
