Pulley Ratio for Alternator - pulsed tach signal.
engine adaptor bolt patterns?
Turned up 4BT
So, I have this quandary -
Anyone got a spare crank pulley they can verify the diameter of for this thread. . ?? I measured (in the truck), about 6. 75 inches. . If so, the pulley ratio should be 3:1, (6. 75 to 2. 25 inches) which would mean I should calibrate my VDO electronic tach with 3 pulses per revolution, correct. . ???
Linc
Welp. . Cal'd the tach according to the instructions, and no luck... I also noticed my voltage did not come up to 14 V like it did earlier. . AGGH!!!
I will probably yank the alternator & have it bench tested to see if it's on the fritz, (160k miles) and have the tach lead tested as well. .
More beer. .
Linc
all this discovery... !! OK - poking around a bit more through the archives netted some better guidance - the Nippondenso alternators are supposed to generate 6 AC pulses / revolution, which means my ASSumption of 3 pulses per engine revolution lacked. . well... a critical multiplier. .
. . should be 18 pulses / crank revolution from the alternator... I will give this a shot & report back...
Linc
bingo! 18 pulses per engine revolution is the magic number. Now it looks like I have a dying alternator - signal dies out after about 20 seconds... !! ugh!
Linc
oops. . UNbingo... . alternator rebuilder says 3 pulses / alternator revolution, so 9 is the magic ##. . Ugh. . will try again... .
Oh yeah - the alternator had 160k miles on it, brushes still had ~50% left, rear bearing was drying out, front bearing was still good... no noise... .
Linc
Linc
Cummins list the Damper at 174mm or 6. 80 inches.
